Fermax Door Entry
Alarm Co
on the drawing i pulled of the manuals site it is fermax ref 3569,
it is a six phone/monitor, single entry with video and audio system
with 1 ac power supply ,, voltage fine
1- dc power supply ,, voltage ok
1- 4 way video distributor, mod no 2449
1-2 way video distributor mod no 2448
this installation is two years old
was run in 8 core alarm cable and rg59
and is all in working order appart from
no camera trigger when visitor calls residents phone
but resident can get piture by pressing monitor button on phone
how does the triger work?
when you call a phone does the phone send the triger back to 2 on the video distributor , then the distributor send triger to camera from 3 .?
if i triger camera from monitor phone so i do get picture i get 8 volts positive
on ct at camera
still no ideas????? :( :!:
It really sounds like a Fermax technical job to me, it must be the video switching, if the audio and buzzer to the phones work when the front panel is calling and you can manually select video from the handset then it "has" to be a switching fault.
Fermax tech should be able to tell you how the signal to the phones is handled, I would assume the phone itself uses the same signal as the buzzer and simply turns on it's video display?
You don't say (or I didn't see) if this is a multi door install with a switcher as these can give trouble....
Give Fermax a rocket and get them to help you! B)
My Amateur Radio Forum
