Odyssey 5 Connections To 9651
mattj
Following on from the top advice about replacing a scanny 9200 with a 9651, I thought I'd ask for the connections to an Odyssey 5 and while I'm at it anything to watch out for.
I'm not being lazy just cautious, honest!
Thanks again.
Matt
you have to be carefull with the print on the 9651 panel for the bell box its looks like c2 and nc2 but this is for another board you need the print on the edge of the board
op1 =bell trigger
op2= strobe
op3= not used
TR= tamper return
then under ther is the terminal for internal loud speaker
and youre 12v poss and neg will go to the aux out put under the loudspeaker output
