SuperFly Posted September 26, 2007 Posted September 26, 2007 I've just moved into a house with an Abacus 8 alarm panel, the previous owners didn't have a code for the unit and therefore neither do i. Is there any way to either find the code or reset it? I could also do with a manual if possible The details on it are Abacus 8 127, V23 8 (from the top of the EEprom chip inside) V235 (or 23S) on the display panel when i power up the system) If it can't be done can anyone recommend a reasonable priced, suitable new unit for a swap out, it seems to be run on passives only,. i'd like to add a remote keypad by the front door too. Any other advice would be useful, i'm not trained directly in alarm systems but have extensive experience and training in industrial electrical and electronic systems so i'm not too worried about swapping the panel over if required. Thanks in advance
alterEGO Posted September 26, 2007 Posted September 26, 2007 I've just moved into a house with an Abacus 8 alarm panel, the previous owners didn't have a code for the unit and therefore neither do i. Is there any way to either find the code or reset it? I could also do with a manual if possibleThe details on it are Abacus 8 127, V23 8 (from the top of the EEprom chip inside) V235 (or 23S) on the display panel when i power up the system) If it can't be done can anyone recommend a reasonable priced, suitable new unit for a swap out, it seems to be run on passives only,. i'd like to add a remote keypad by the front door too. Any other advice would be useful, i'm not trained directly in alarm systems but have extensive experience and training in industrial electrical and electronic systems so i'm not too worried about swapping the panel over if required. Thanks in advance it is not the kind of info that can be given out i'm affraid. but there are much better systems available now, i would recommend the Gardtec 490x, very good with a built in dialler which will contact any 4 numbers you like whrn the alarm goes off, and much more. look at the spec here http://www.riscogroup.co.uk/Products.aspx?...id=86&id=17
tinnitus Posted September 26, 2007 Posted September 26, 2007 I've just moved into a house with an Abacus 8 alarm panel, the previous owners didn't have a code for the unit and therefore neither do i. Is there any way to either find the code or reset it? I could also do with a manual if possibleThe details on it are Abacus 8 127, V23 8 (from the top of the EEprom chip inside) V235 (or 23S) on the display panel when i power up the system) If it can't be done can anyone recommend a reasonable priced, suitable new unit for a swap out, it seems to be run on passives only,. i'd like to add a remote keypad by the front door too. Any other advice would be useful, i'm not trained directly in alarm systems but have extensive experience and training in industrial electrical and electronic systems so i'm not too worried about swapping the panel over if required. Thanks in advance this is a nice little panel, we used to fit loads. its not difficult for a qualified engineer to make it do what you want. probably 1-2 hours work, based on what you have said you need done (depends on cable run to front door too). when you power it up, what does it say after 10 seconds or so?
johnll Posted September 27, 2007 Posted September 27, 2007 my dear friend this is not a help you do it yourself site .the only advise given is get an alarm guy and pay up. i think your box needs to be defaulted and reprogramed with new key codes .i have the same problem but nobody will help.i will probley be cast out for saying this but if you read the rules carefully you will see what i mean.
Chorlton Posted September 27, 2007 Posted September 27, 2007 my dear friend you or anyone else could be a criminal wanting to know how to "reset" someones elses alarm. You have been advised it should take a pro engineer 1-2 hrs to get it running. This is not a "tell me anything I want to know site" it is a security community forum. The rules quite rightly state we cannot provide "engineer/defaulting information" for that reason alone. If you want advise about other aspects of your alarm, cctv, door access, fire system etc ask away. Imagine you coming back in 3 months saying "I was burgled because you lot gave a local crim my alarm defaulting info" - get my point ? C.
Guest anguscanplay Posted September 27, 2007 Posted September 27, 2007 my dear friend this is not a help you do it yourself site .the only advise given is get an alarm guy and pay up. i think your box needs to be defaulted and reprogramed with new key codes .i have the same problem but nobody will help.i will probley be cast out for saying this but if you read the rules carefully you will see what i mean. if by alarm guy you mean someone with the training, ability, tools and insurance then your probably right but please it isnt a conspiracy or a secret club it`s usually insurance lead and it`s like that for your protection explain the thoery - yep explain how to do it - nope Angus 2
johnll Posted November 29, 2007 Posted November 29, 2007 if by alarm guy you mean someone with the training, ability, tools and insurance then your probably right but please it isnt a conspiracy or a secret club it`s usually insurance lead and it`s like that for your protection explain the thoery - yep explain how to do it - nope Angus 2 have you moved yet ?
