N/o - N/c Having Trouble
andymac
Hi all (almost finished install now!!),
OK, just added nova wireless to my 816, had to get additional expander to do so. 3 zones from reciever wired into panel using 2 wire method. !st zone wired with 12v input then to keyswitch on panel to set and unset.
The problem is when the reciver is set as N/C the set and unset buttons on the keyfob are back to front, so i switched to N/O ,now all wireless sensors go into alarm mode?
Pls help!
Thanks
Andy
Guest anguscanplay
Pls help!
Thanks
Andy
redo it using a zone set to type " keyswitch " rather than the input
Guest anguscanplay
Thanks Angus,
my panel is quite old and does not have the option to change a zone type to 'key switch'.
Ta,
Andy
thats older than some of the guys on here
ha ha ha,
will i have to change the wiring type on the zone expander to 4 wire, then wire from the wireless receiver into expander as normally open devices?
Andy
Guest anguscanplay
ha ha ha,
Andy
afraid that wont do either andy - you sure you cant prog the channel on the reciever to work O/C without the others following suit - it might be the " advanced programme settings " , but tbh its that long I forget ( the new radio stuff all plugs on see )
ok thanks Angus,
i'll have another read of the instructions.
Andy
so thats lucky i'm still breathing then, i'm older than any panel thats got a transistor somewhere in it :cold2:
regs
alan
alan i thought you could remember when panels still had valves in them ?
(hands in membership of round table and honery rsty tin of ovaltine) ;)
Life is like a box of choclates.....if you dont get there first your left with all the naff ones
The first computer I programmed had valves in it!
There's a prize for whoever guesses what it was.... B)
