andyb Posted September 28, 2007 Posted September 28, 2007 hi does any body have a downloadable user manual for above , last manager mislayed ours and we need to reset codes ,thanks andy
amateurandy Posted September 28, 2007 Posted September 28, 2007 hi does any body have a downloadable user manual for above , last manager mislayed ours and we need to reset codes ,thanks andy Hello Andy, Did you mean reset or change? Reset is normally an engineering function that should not be in a user manual. As you will know from the site rules (you have read them, haven't you?) engineering information cannot be made available. Your wording "last manager" implies this is some sort of commercial premises in which case you should have a manitenance contract; the maintenance company can sort this out for you - both change or reset - and supply user instructions. If you know your existing code and just want to change it please say so and hopefully someone will dig out the relevant instructions.
FASTCAR Posted September 28, 2007 Posted September 28, 2007 Hi , Just go to the website and request one , they will send it no problems. guardall Regards.
