Guest Doug Posted April 25, 2004 Posted April 25, 2004 Similar post to hihi I`ve got a toshiba a40 laptop, is there any way i can combine it to view a 12ghz wireless cctv instead of tv or a dedicated monitor. What, if any is available out there i can plug into laptop to hook up to the reciever, there is 4 usb2.0`s, monitor and printer port available Regards
Guest msecure Posted April 27, 2004 Posted April 27, 2004 Have seen & bought a USB device that can plug 4 CCTV cameras & turn any PC with USB into a DVR. If you need more info, will try to get the manufacturer for you.
Guest Doug Posted April 27, 2004 Posted April 27, 2004 Thanx 4 reply, if u can send info would b much appreciated, D.
