Guest anguscanplay Posted September 30, 2007 Posted September 30, 2007 cant believe im agreeing with Angus here but there is a back focus screw on this that should need adjusting you can do it on your workbench first before fitting the unit - advantage is then when you zoom it to cover the area you shouldnt need to refocus ( lock down the little adjuster arm too so it doesnt move over time )
Fixer Posted September 30, 2007 Author Posted September 30, 2007 you can do it on your workbench first before fitting the unit - advantage is then when you zoom it to cover the area you shouldnt need to refocus ( lock down the little adjuster arm too so it doesnt move over time ) Thanks for your help; I will try it again later, out flying all day today I fly gassed up
