louos31 Posted September 30, 2007 Posted September 30, 2007 I have a Euro-Meridian One intruder alarm system and yesterday the alarm went off (a false alarm). The system reset itself and all seems to be fine, except that the box on the front of my property is still flashing as though the alarm has been activated. I have no idea how to reset that and would be grateful for some advice on how to do this. If all else fails I will call out the company who installed it but they are not open at the weekend, I would have to take time off work etc etc, so if there is a way of doing this myself then that would be really helpful. Many thanks
rosco Posted October 2, 2007 Posted October 2, 2007 Hi, Have you tried entering the code again at the panel. Most panels when set off require the code to be entered to silence the sounders and then to be entered again to return the system back to standby/day mode.... hope this helps
danpread Posted November 30, 2007 Posted November 30, 2007 on your display it will show the cause of the activation and the A button will be illuminated. if you are happy with what caused the activation press the no key to reset it. dan
