HELP
Guest johnie
Guest johnie
can anyone help me find a instalation or a engineers manual for a menvier TS700 control panel
when i put the engineers code in the display says engineer on site and i cant get out of engineers mode and the alarm keeps arming itself when it shouldnt
can anyone help or even some advise would be good
thanks
WHEN YOU PUT THE ENGINEER CODE IN THE DISPLAY SHOULD SHOW E1
SYTEM IS NOW IN PROGRAMMING MODE
WHEN YOU EXIT ENGINEER MODE IT WILL SHOW ENG ON SITE
ENGINEER MANUAL IS AVAILABLE TO BONA FIDA ENGINEERS AT THE MENVIER WEB SITE
Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
Also, to clear the eng on site message, enter customer code then press ESC, dispay should then change to OPEN
Guest johnie
thanks guys, its sorted now system is now up and running :D
