Scantronic 9448 Internal Sounder Volume
melv
Hi. Have just moved into a house with a Scantronic 9448 already installed. My only problem with the system is that the keypad and entry/exit tones are a little loud and the tone is very penetrating. I live in a terraced house and this problem means that I am conscious of annoying my neighbours when I set or disarm the alarm late at night. Can I turn down the volume of the internal sounder so that these tones are not as loud? Or can I get an approved engineer to do it for me? Many thanks.
not a big job obviously,
your best bet is have an engineer come in, service, test, reset the codes and fine tune your system to your needs.
prices vary, so ring a few local NSI or SSAIB approved companies, one big and a couple of smaller ones and get quotes before you engage anyone.
they most likely will want to set up a service and maintenance agreement, this is no bad thing as it will give to access to a 24 hour service for faults and your system is checked every year (well should be :rolleyes: ), but beware if you use the call out service especially out of hours you may be charged on top as the cost is usually for the availability of the service - not the use of it (unlike your Gas Boiler insurance), so again be sure of these charge rates before you sign up to save arguments later ;) .
regs
alan
Guest anguscanplay
I`ll do it - and we cover the labour cost of the callout too ( but not if it`s your fault, or the cost of the equipment )
