Prem 48
hi is the texecom premier 48 a good alarm panel to put on my house i see that it can do home automation has any one used one of these before and how good is it with regards to the home automation. or would i be better of saving my money and just use a texexcom veritas insted any help would be great thanks
Surelyy the same answers would apply as last time you asked??
Growing old is mandatory, growing up is optional
Guest Dave the alarm man
proper commerical type panel, like everything else requires more module, inputs & relay to perform the task which is secondary to the function of alarm
Hi
Yes, its a good panel, although not many on here would vouch for it as the Texecom range is supplied through a wide range of distribution and retail partners. (granted, the Premier is not a DIY marketed (or really suitable) panel unless you are competent...ooops better not use that word.. :bruce_h4h: )
The Premier range do support X10, through an interface though - you get a cable from texecom to connect it up. You can assign events to x10 commands, so pir motion could switch a light on for example. I would go for a Premier in place of a Comfort panel anyday - ask here for views on Comfort and I can imagine the replies...
I use a Premier 168, with heaps of PIR's (one in each room of the house), so I have occupancy detection. This can switch lights on and off as required. I also have smokes and CO heads too. If my better half leaves the kitchen light on, it can switch it off if no occupancy is detected (no PIR activity) after a set time... I do this thorugh Homeseer.
All this stuff feeds into Homeseer, and nearly all the zones appear as Homeseer devices, where you can script and get stuff easily working.
There is also a neat ( and cheap) relay board that you piggy back into the Premier... useful to swicth stuff if you dont go the PC route.
Make sure you get a UDL cable to programme the panel, as the RKP route would cause you great pain. (not impossible, just a PITA)
Hope that helps - its a start
DJ
  • 2 months later...
Hi
DJ
Hi,
I have just fitted a Premier 48 at home, I would like to ask you a couple of questions..
How do you find the Smoke detectors ? I was advised that it would cause false alarms and not to go that route. Have you had any false issues with the smoke detectors?
I will lookup homeseer, but if you dont mind I would like to know what you bought to set this system up.
Thanks
