arfur mo Posted October 11, 2007 Posted October 11, 2007 GJD can be linked to the alarm system, won't be graded but its DIY anyway.As fo adding lights they don't have to be taken back to the GJD head end Alan, you can just run them to an expander, and from there back to the GJD head end in alarm cable. thats true of the 2 channel set up with remote customer unit, i was thinking of the single channel (solatair?) unit for cost savings. new controller looks good but since part 'p' i've dropped out of fitting security lighting, often sold as a 'make weight' to make the less exotic alarms on larger houses more viable for me. big issue is if a bulb go's they insist you come and change it then have to explain the cost of a call so can lead to possible mistrust and arguments with the client as most my calls are north london area and i live in Essex. regs Alan If you think education is difficult, try being stupid!!!!
TSS Posted October 15, 2007 Posted October 15, 2007 thats true of the 2 channel set up with remote customer unit, i was thinking of the single channel (solatair?) unit for cost savings.new controller looks good but since part 'p' i've dropped out of fitting security lighting, often sold as a 'make weight' to make the less exotic alarms on larger houses more viable for me. big issue is if a bulb go's they insist you come and change it then have to explain the cost of a call so can lead to possible mistrust and arguments with the client as most my calls are north london area and i live in Essex. regs Alan Alan, suggest fitting diodes as reccomended by system Q - makes bulbs last longer TSS Communication is "A question asked, and an Opinion given." I offer mine to help you with yours. Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
TSS Posted October 15, 2007 Posted October 15, 2007 Hi,Can anyone recommend a reliable external detector that won't false alarm too often? Thanks Optex VX-402 TSS Communication is "A question asked, and an Opinion given." I offer mine to help you with yours. Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
alterEGO Posted October 15, 2007 Posted October 15, 2007 Alan, suggest fitting diodes as reccomended by system Q - makes bulbs last longer ithought that was a secret, i spark once told us about that.
arfur mo Posted October 15, 2007 Posted October 15, 2007 Alan, suggest fitting diodes as reccomended by system Q - makes bulbs last longerthat will have the effect of 1/2 power (due to half wave rectification), not tried it so not sure if the light output would be sufficient in all cases, might be better to go with 300 watt lamps, but still a good tip.regsalanHi,Can anyone recommend a reliable external detector that won't false alarm too often?Thanksyou might have a gander at Risco's WatchOut, come in pir or dual tec, ignores animals and moving bushes etc.regsalan If you think education is difficult, try being stupid!!!!
