marksandsparks Posted October 13, 2007 Share Posted October 13, 2007 Fitted a Texecom alarm a couple of years ago and fitted the ADE Reson8 bell box plus the same dummy box with a flashing LED module. Neither the LED's in the live box or the dummy box have ever been very bright, which is rather frustrating banghead when all my neighbours' bell boxes flash brightly (different boxes of course). In fact you have to stand quite close just to see my dim lights. I've tried moving the LED module closer to the blue lense but that didn't work. There's no problem with the voltage, the cable doesn't have to go very far to the live box. Is it because the Reson8 is designed like this? Badly. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/ Share on other sites More sharing options...
alterEGO Posted October 13, 2007 Share Posted October 13, 2007 marksandsparks said: Fitted a Texecom alarm a couple of years ago and fitted the ADE Reson8 bell box plus the same dummy box with a flashing LED module. Neither the LED's in the live box or the dummy box have ever been very bright, which is rather frustrating banghead when all my neighbours' bell boxes flash brightly (different boxes of course). In fact you have to stand quite close just to see my dim lights.I've tried moving the LED module closer to the blue lense but that didn't work. There's no problem with the voltage, the cable doesn't have to go very far to the live box. Is it because the Reson8 is designed like this? Badly. it is because the reason8 is a better door stop then a bell box. for bright LED's you can't get better then a gardtec nova 2. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181019 Share on other sites More sharing options...
marksandsparks Posted October 13, 2007 Author Share Posted October 13, 2007 alterEGO said: it is because the reason8 is a better door stop then a bell box. As I thought Thanks alterEGO. That's obviously you're favourite. Does anyone else have any other suggestions so I can make an informed choice for replacement. Also will my flashing LED module work alright with a new dummy box or should I get a better one of those. I have one of these at the moment http://www.alertelectrical.com/Burglar-Int...Module-FLED.asp Anyone need a doorstop? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181021 Share on other sites More sharing options...
arfur mo Posted October 13, 2007 Share Posted October 13, 2007 if the siren works ok as a loud siren, and if the strobe flashes as a bright strobe why change the unit simply for the dull (often called wally lights) led's why not simply fit some bright self flashing 12 volt ones from maplin's or rs components for a few pence? disclaimer! remember please there may be high voltages present within the casing, and the effect of gravity often has unfortuate effects on the human body, so work sane and work safe. regs alan If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181031 Share on other sites More sharing options...
kka Posted October 13, 2007 Share Posted October 13, 2007 my choice gardtec novagard 2, this is what i settled on, leds are very bright and can be seen 1/4 of a mile away in dark. execellent deterent imo B) i did a lot of research when changing from the pyronix belle, and i choose it on the bright flashing lights...............mind i am a bit mad on flashing lights Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181040 Share on other sites More sharing options...
antinode Posted October 13, 2007 Share Posted October 13, 2007 Can't go wrong with a Novagard in my opinion. Probably the best sounder out there. I think I would rather have a C Type housing with a Kinetic horn sounder in it than a Reason8... Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181045 Share on other sites More sharing options...
alterEGO Posted October 14, 2007 Share Posted October 14, 2007 antinode said: Can't go wrong with a Novagard in my opinion. Probably the best sounder out there. I think I would rather have a C Type housing with a Kinetic horn sounder in it than a Reason8... qfa i wonder if the name stood for the 8 reasons not to use them i'll start the list 1. THEY ARE **** KKA: the reason8 is followed close by the belle as second worst siren, it could only get better switching from a belle. IMO only gardtec and texecom can make decent bells.[texecom come 2nd to tech though ] Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181051 Share on other sites More sharing options...
marksandsparks Posted October 15, 2007 Author Share Posted October 15, 2007 2. THEY DON'T MAKE A VERY GOOD DOORSTOP Thanks to all. Is this a good price: http://www.ahsupplies.net/30300/info.php?p...ch=&sought= Any other places you know I could get one cheaper? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/21015-reson8-bell-box/#findComment-181139 Share on other sites More sharing options...
