Optima Xm6 Bell Box Wiring
paulolivier
just wiring a new bell box to an optima xm6 panel. the old box was wired as-
strobe +ve blue
strobe -ve white
tamper return yellow (T)
0 volts green (A)
12v +ve red (D)
trigger -ve black (B)
the new bell box is a lyntec has contacts for
hold +ve
hold -ve
tg-
stb-
return
is this correct
hold +ve red
hold -ve green
tg- black
stb- white
return yellow
tamper return and 0 volts are linked in the panel.
strobe +ve blue
strobe -ve white
0 volts green (A)
12v +ve red (D)
hold +ve
hold -ve
tg-
stb-
return
is this correct
hold +ve red
hold -ve green
tg- black
stb- white
return yellow
yes...
If at first you don't succeed...don't try skydiving!
Guest anguscanplay
yes...
except for the tamper
Looks OK, but take that link out from Ov and the Tamp return when you fit the new box.
thanks for the replies. looks like i have a faulty bell box then. i have connected it up and the siren just sounds continuously and the strobe does not flash, plus entering the code on the panel does not silence it. i will double check the wiring to make sure.
