Upgrading Castle To Texe. Premier - Eol Resistors Swapout!?
Matt Ward
Hi,
I am replacing a Castle Care-tech to a Texecom Premier 24. From my experience, the Castle panel uses a 1k(CCT) and a 13k(A/T) resistor for EOL. The texecom panel uses two 1k resistors. There are about 14 zones on the existing panel.
I'm giving this guy a price for the upgrade, but I cannot remember if there is an option in the Premier 24 to change the EOL resistor values.
Do I have to go round all the devices and swap out the resistors?
Thanks for any help!
Matt
(I am a trade member)
Guest Dave the alarm man
those values are wrong mate, BTW prem will not allow to define eol values
which castle product is coming out? d/p & iD used on some systems BTW
You will have to change the resistors I think texecom use 2k2 EOL & 4K7 SHUNT be carefull to check that the castle panel is not using ID biscuits as they may be some rewiring involved.
Damn, didn't think of that!
It's not a 2200/2300 or 2700. The keypad looks like this...
http://www.castle-caretech.com/pdfs/1600.pdf
(it might not actually be a 1600, could be a 1700. I cannot remember the difference)
...but you're quite right, didn't think of biscuits. 14 Zones seems alot of zones for a small panel?
Matt
Matt
shouldn't need any rewiring even if it is ID, i know gardtec do a id expander and i'm sure texecom do a 30 point id expander for the premier aswell.
Version 8 software allows definable eol resistors, options are: 1k/1k, 4k7/6k8, 2k2/4k7 and 4k7/4k7.
not lcd?, the plastic's are used for panels that don't use 1 & 13's
unless you know what the product is :whistle:
on the 48 upwards yet? zone by zone or gobal?
On the 24 upwards, zone by zone
Guest anguscanplay
that is a good idea, i'm gonna ask risco to think about that. how long has version 8 been out?
don`t take that long to swop some resistors, plus it means you get to check inside the device too
