Need Help
duffy
At the moment my shop has a 16 cam dvr system of which 1 of the cams is a Dynamic 2 Panasonic WV-CS850 which is set on a 90` motion span. But i need to control it manually.
I been looking at a WV-CU550B Controller and was wondering if possible to wire cam`s ptz straight from it using RS-485 input or do i need to buy a matrix ?.
When i took over shop it used to have 4 WV-CS850 but they only left the middle cam and 4 baxall ZR4 boards in Box`s and 1 baxall ZT53 controller.
Any Help would be greatly appricated, as just started up in business and shop is losing so much through shoplifters life is getting hard.
  • 6 years later...
hello sir iam a newbie too i read your post and if its any help i also have a zt53 8 channel controller which i purchased fully working but without the socket on the rear 12 pins and cant use if its help to you let me know
was hoping he might of thrown zt53 into corner somewhere and i could get the socket to use with mine cant find anywhere to locate one but six years O_O should of looked more closely i think.
