Stevew Posted October 19, 2007 Posted October 19, 2007 Hi, My alarm keeps going off even when it is not armed and the 'attack' LED is lit once i enter my code to turn it off. The alarm was here when i moved in and there are 2 emergency panic button things around the flat which have deffinitly not been pressed down. Are these causing this? and is there a way of just disabling them? Thanks
alterEGO Posted October 19, 2007 Posted October 19, 2007 Hi,My alarm keeps going off even when it is not armed and the 'attack' LED is lit once i enter my code to turn it off. The alarm was here when i moved in and there are 2 emergency panic button things around the flat which have deffinitly not been pressed down. Are these causing this? and is there a way of just disabling them? Thanks yes it is the p.a. circuit at fault. one may be faulty, i/m sorry but we can't tell you how to disconnect them as it would be the most secure thing to do. contact a company from the list in the link on the homepage for a local company, untill then if you don't reset it after you put the code in it should not go off again.
arfur mo Posted October 19, 2007 Posted October 19, 2007 yes it is the p.a. circuit at fault. one may be faulty, i/m sorry but we can't tell you how to disconnect them as it would be the most secure thing to do.contact a company from the list in the link on the homepage for a local company, untill then if you don't reset it after you put the code in it should not go off again. as alterEGO has said, might be a duff reed or a bad connection in one of the buttons, try gently tapping the casing of each button with a screwdriver handle (not to big screwdriver ) if alarm go's off this will give you a clue. could also be a duff standby battery, a small mains disconnection can cause the panic circuit to activate so best have the system checked over properly and serviced. regs alan If you think education is difficult, try being stupid!!!!
