Melcom Micron Pir's On An Optima Compact Panel
David228
I have an ADE Optima Compact 6 zone panel and have Melcom Micron PIR's which are N/O type. I am aware that the ADE panels are N/C.
What do I have to do to wire them up?
I have read that I will need some 33 Kohm pull up resistors - why are they required and where would I buy a couple of them? Would it be easier just to get some N/C PIR's
The system will have two PIR's downstairs, a contact on front door and a keypad upstairs. The PIR's are on the one zone. The house is a fairly new one which had alarm wiring pre-fitted . The downstairs zone has a wire looping into kitchen then terminating in the lounge.
Thanks
Thanks
Hi David,
it's very rare to find pir's specifically designed for alarm use that are just o/c only, so are you sure (as i din't know of this model)? my advise is otherwise don't try and bodge it to save a few groats, but get decent pirs, they won't break the bank.
so as you understand they only go n/c when powered and no movement detected.
you have enough zones available, so split you pirs onto seperate ones, then if you have any alarm activations you will know which one caused it so easing any later fault finding diagnostics.
regs
alan
Micron PIR
Manufacturer: Lynteck
Specifications:
Detection method: Dual pyro-electric sensor
Operating voltage: 9 to 15Vdc
Current draw: 17mA
Alarm output: Normally closed relay
Alarm period: 2 to 5 seconds
Pulse count: 1, 3, or 5
Operating temp: -10 to + 50C
This is the PIR as it shows the contacts are closed
6 zones
+ve loop, programmable functions in each program.
Tamper
-ve loop, internal sounders in day, full alarm in set.
The detectors will wire up without resistors
Micron PIR
Specifications:
Current draw: 17mA
thanks davboy,
i thought as much but when unsure did not want to give conflicting advice
the original poster - no resistors needed if wired in 'conventional' loop configuration
regs
alan
Dave228, you will get the resistors you need from maplins or rs components or similar. never used this panel / detector so cant give any more advice. if you have researched this and are sure the resistors will work then its certainly the cheapest option. Is the cable supplying both detectors an 8 core? (does it have 8 small cables inside?). if so, you can have both detectors on a separate zone.
Thanks for the replies so far, the PIR I have is actually a 'Melcom Micron Plus', it appears different to the one that Maplins are selling and the info sheet states the alarm contacts are N/O and tamper is N/C.
The cable to PIR's is 6 core.
Thanks
Thanks
you could gain individual zones even with a 6 core looped once. you could either upgrade the panel to one capable of EOL wich only needs two cores for zone and tamper.
there is another way you could get individual zones off the 6 core and tamper using the panel you have but it isn't to standards.
ps: if the PIRS are normally open just get rid and get N/C.
