davetherave69 Posted October 21, 2007 Posted October 21, 2007 hi what is the best form of smoke machine to install in a large domestic property it will be mounted in the lounge as this is were the most expensive gear is the property has an alarm already installed. also how do these get trigerd does it get wired to the out put of the alarm i would only want it to go of if the sensor in the lounge is trigerd is this all possible any help would be great.
Guest Dave the alarm man Posted October 21, 2007 Posted October 21, 2007 hi what is the best form of smoke machine to install in a large domestic property it will be mounted in the lounge as this is were the most expensive gear is the property has an alarm already installed.also how do these get trigerd does it get wired to the out put of the alarm i would only want it to go of if the sensor in the lounge is trigerd is this all possible any help would be great. n/o relays alarm & circuit mimic, also set input to machine, you going fork out for one of these in a house? & going to look at in on the wall?
davetherave69 Posted October 21, 2007 Author Posted October 21, 2007 n/o relays alarm & circuit mimic, also set input to machine, you going fork out for one of these in a house? & going to look at in on the wall? hope to mount it in a cupboard with a hole in it so it will be not be seen thing they are a good idea as you want be able to grab any thing and run when the alarm is going off do you not think it will be a good idea.
Guest Dave the alarm man Posted October 21, 2007 Posted October 21, 2007 do you not think it will be a good idea. whate ever floats your boat, where the machine coming from?
davetherave69 Posted October 21, 2007 Author Posted October 21, 2007 whate ever floats your boat, where the machine coming from? ever smoke clock or bandit do you have any prefrance which is good or bad
Cubit Posted October 21, 2007 Posted October 21, 2007 do you not think it will be a good idea. Positively underwhelmed with advice. Not exactly the best idea we've seen i'm afraid.
tinnitus Posted October 21, 2007 Posted October 21, 2007 ever smoke clock or bandit do you have any prefrance which is good or bad Some smoke machines are very effective. check this .very heavy though, as i recall 25 kilo's with canister. i usually hang from the fixings first to see if it will be ok. also, the nozzle gets extremely hot so make sure the hole you will make is wide. i love fitting these, well testing them. ours are triggered by the alarm, intruder output.
brizee Posted October 23, 2007 Posted October 23, 2007 smoke cloak are really good ive worked with then a fair few times. last residential we did had six cloaks mounted above skirting boards then hidden with matching rad covers, it looked good. Id be aware of the power consumption, itll probably require a new supply if you require more than one. Ask for gary to do the install if you use them, very efficient and nice guy too.
Smoke Screen Posted October 29, 2007 Posted October 29, 2007 Just a quick note re: the video link above. That is neither a Bandit system nor am I entirely sure it is a system fitted by Abel (regardless of the publishers YouTube ID). Be sure of your sources if possible. Regards, Matt Matt Gilmartin, Sales Director T: +44(01205) 821111 | F: +44(01205) 820316 info@smoke-screen.co.uk | www.smoke-screen.co.uk Head office: 1-2 North End, Swineshead, Boston, Lincs PE20 3LR Registered in the UK no. 2728491
TSS Posted October 29, 2007 Posted October 29, 2007 hi what is the best form of smoke machine to install in a large domestic property it will be mounted in the lounge as this is were the most expensive gear is the property has an alarm already installed. As always my personal preference is Smokecloak - I have 3 to fit next week... TSS Communication is "A question asked, and an Opinion given." I offer mine to help you with yours. Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
