clive123 Posted October 23, 2007 Posted October 23, 2007 Hi, i have just installed a texecom premier 412 alarm system in my house, everything works fine and was easy enough. but being my first alarm install i am not sure on how to have it hooked up with dial in access with a wireless device for checking logs etc. any advice would be appreciated. also, is the pc-com cable a normal rs232 cable? or does that little box in the middle of it actually do some kind of conversion? if it is a normal cable, does anyone have the pinouts? thanks for help.
InspectorGadget Posted December 11, 2007 Posted December 11, 2007 Hi, i have just installed a texecom premier 412 alarm system in my house, everything works fine and was easy enough. but being my first alarm install i am not sure on how to have it hooked up with dial in access with a wireless device for checking logs etc. any advice would be appreciated.also, is the pc-com cable a normal rs232 cable? or does that little box in the middle of it actually do some kind of conversion? if it is a normal cable, does anyone have the pinouts? thanks for help. I thought I was going overboard with a Prem48 for my house What made you go for the 412? I have the comIP module and should be finishing up on the install this weekend, though programming looks like a job and a half with all the settings. Wintex should help out there.
1019641 Posted December 11, 2007 Posted December 11, 2007 I thought I was going overboard with a Prem48 for my house What made you go for the 412? It's the "international Panel" it has ONLY 12 Zones Comes with 4 onboard and expandable to 12 Dean Wholey NCC Dean.Wholey@Ntlworld.com
