Guest wizbongre Posted April 27, 2004 Posted April 27, 2004 Okay, I've given up on the DIY install I've had a few quotes and seem to be getting the following - Novar ADE Accenta 8 - recommended as the control panel. Is it any good?!
Guest dale Posted April 28, 2004 Posted April 28, 2004 It will probably do the job you want, not the panel I would choose. But it is a cheap and cheerfull panel. Personally I would recommend the Texecom VR8 as it has a bit more functionality than the Accenta 8, and isnt that much more expensive.
