Map Security Posted October 27, 2007 Posted October 27, 2007 I have just installed a 500GB HDD into a brand new Neotech (NTIC) 16CH JPEG2000 DVR........... The pictures on screen are all black and white.... Any idea's what I should to reset DVR or troubleshoot.? Anyone had a similar experience? Ma
whistle Posted October 27, 2007 Posted October 27, 2007 Did you power it up without any cameras connected? if so it auto sets its self to NSTC not pal, this could be the problem.
Guest Dave the alarm man Posted October 28, 2007 Posted October 28, 2007 Anyone had a similar experience? yes using a mono monitor
advancedprotection Posted October 28, 2007 Posted October 28, 2007 make sure monitor is connected and turned on first before dvr/ Trade Member It's nice to be important but it's more important to be nice!! Martin Hanfo CCTV - Intruder Alarms - Access Control - Security Lighting - Locks Covering South Wales 07903 967045
camerabloke Posted October 28, 2007 Posted October 28, 2007 use colour cameras Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Map Security Posted October 28, 2007 Author Posted October 28, 2007 Did you power it up without any cameras connected?if so it auto sets its self to NSTC not pal, this could be the problem. Yes I did power up without any cameras connected...so this really sounds like the problem... Can this be resolved by resetting all features back to default? Many thx for your help...will keep you posted....I do not have the unit currently nearby! Nice one! Map
Mavrick_001 Posted October 29, 2007 Posted October 29, 2007 usally, down power it power up with cameras connected should be ok if not post back and will offer some more solutions CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Map Security Posted October 29, 2007 Author Posted October 29, 2007 Thx Maverick but this does not stop the problem. Basically I added the 500GB drive and powered up to make sure it was working....This was the first time the machine was started and hence I'm convinced it has selected NTSC instead of PAL giving black and white pictures. I need to reset DVR somehow...... Will keep all updated as this machine seems to be very popular in the field!
TEE Posted November 5, 2007 Posted November 5, 2007 Thx Maverick but this does not stop the problem.Basically I added the 500GB drive and powered up to make sure it was working....This was the first time the machine was started and hence I'm convinced it has selected NTSC instead of PAL giving black and white pictures. I need to reset DVR somehow...... Will keep all updated as this machine seems to be very popular in the field! I HAVE HAD THE SAME PROBLEM AS WELL LONG TIME AGO TO GET OVER IT U HAVE TO POWER UP ALL CAMERAS (COLOR) AND MAKE SURE THEY ARE CONNECTED TO DVR FIRST THEN TURN ON THE DVR LAST
