dwdw Posted October 28, 2007 Posted October 28, 2007 hello all I am trying to set up a wickes rascal, model number 72915, but have lost the entry number any ideas on how to enter a new pass number. regards Dave
alterEGO Posted October 28, 2007 Posted October 28, 2007 hello all I am trying to set up a wickes rascal, model number 72915, but have lost the entry number any ideas on how to enter a new pass number. regards Dave crash it to factory settings using the engineer manual, if you don't have one ring an engineer.
Mavrick_001 Posted October 29, 2007 Posted October 29, 2007 My missus is a manager at wickes and often rings me for tech support or advice on anything electrical... I should charge lol. The panel will come with a programming manual, if you have lost the code then as said you will need to put it back to factory settings and re-program it, otherwise call the wickes store you got it from or your local store, they have numbers of tech support for their products and they will give you all the help you need. Pointless calling an engineer out because hardly any of us work with wickes, b&q kit etc..... CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
alterEGO Posted October 29, 2007 Posted October 29, 2007 Pointless calling an engineer out because hardly any of us work with wickes, b&q kit etc..... not pointless at all as this panel was just re-branded as wickes as 'most engineers' will know. Guardall rascal super re-badged in a white metal housing if i remember correctly.
