theboardwalk Posted November 2, 2007 Author Posted November 2, 2007 Hi yes if i specify the ip given to the DVR by the router it is straight on, sorry what is a tracert but i think its going straight to the router not via the internet
amateurandy Posted November 2, 2007 Posted November 2, 2007 Hi yes if i specify the ip given to the DVR by the router it is straight on, sorry what is a tracert It traces the route messages take over networks/internet. Start, run type in cmd and press OK - a black window appears. Type in tracert aaa.bbb.ccc.ddd (the external IP address) and see if it gets there or gives an error.
theboardwalk Posted November 2, 2007 Author Posted November 2, 2007 It traces the route messages take over networks/internet.Start, run type in cmd and press OK - a black window appears. Type in tracert aaa.bbb.ccc.ddd (the external IP address) and see if it gets there or gives an error. hi yes the tracert works fine and points straight at the modem ip first then list another couple of ips that i dont know assume they are to do with my isp
amateurandy Posted November 2, 2007 Posted November 2, 2007 hi yes the tracert works fine and points straight at the modem ip first then list another couple of ips that i dont know assume they are to do with my isp What model is the router?
morph Posted November 2, 2007 Posted November 2, 2007 Moving this into the CCTV forums later as its more relevant there. Just so you know where its gone
amateurandy Posted November 2, 2007 Posted November 2, 2007 Moving this into the CCTV forums later as its more relevant there. Just so you know where its gone Good idea.
theboardwalk Posted November 2, 2007 Author Posted November 2, 2007 What model is the router? sorry dont know the model it just says Belkin ADSL Modem with wireless G Router and 54G sorry i cant be more specific
Joe Harris Posted November 2, 2007 Posted November 2, 2007 Hi Theboardwalk, You are actually pretty close to sorting this out now. Look on http://portforward.com/routers.htm under belkin and you will find a model number matching one somewhere on the router. Now that we know we are able to see the router from the net it won't take a lot to set up the port forwarding to allow you to access it from the net. Please try and find your model of router from that list and then we can give you all the info you need to set it up in a matter of minutes. 'J
amateurandy Posted November 2, 2007 Posted November 2, 2007 sorry dont know the model it just says Belkin ADSL Modem with wireless G Router and 54G sorry i cant be more specific When you log in to do the admin it will tell you somewhere - the list pointed to by TheTechGuy will give you a clue, or look for a label on the bottom - most start F5D... Once you've found out the model then portforward.com tells you how to do it.
theboardwalk Posted November 2, 2007 Author Posted November 2, 2007 When you log in to do the admin it will tell you somewhere - the list pointed to by TheTechGuy will give you a clue, or look for a label on the bottom - most start F5D...Once you've found out the model then portforward.com tells you how to do it. have got it F5D7632-4
