suky321 Posted November 5, 2007 Posted November 5, 2007 Hi, I have a 9651 alarm system installed with a 9930 scantronic control panel. I know what the installer mode code is, and how to get out of installer mode. The clocks have recently changed 1 hour back to GMT, but I cannot remember what the code was to get into the time change mode in installer mode. I have lost my user manual and engineers manual, does anyone know what the time change code is, or where I can get replacement manuals? Thanks, SSB.
arfur mo Posted November 5, 2007 Posted November 5, 2007 Hi,I have a 9651 alarm system installed with a 9930 scantronic control panel. I know what the installer mode code is, and how to get out of installer mode. The clocks have recently changed 1 hour back to GMT, but I cannot remember what the code was to get into the time change mode in installer mode. I have lost my user manual and engineers manual, does anyone know what the time change code is, or where I can get replacement manuals? Thanks, SSB. i don't use this particular panel, but most panels will allow the clock to be altered using a 'master' user code. so try your existing known codes one might be a master. regs alan If you think education is difficult, try being stupid!!!!
magpye Posted November 5, 2007 Posted November 5, 2007 Hi,I have a 9651 alarm system installed with a 9930 scantronic control panel. I know what the installer mode code is, and how to get out of installer mode. The clocks have recently changed 1 hour back to GMT, but I cannot remember what the code was to get into the time change mode in installer mode. I have lost my user manual and engineers manual, does anyone know what the time change code is, or where I can get replacement manuals? Thanks, SSB. User Code 01 or a Tag is required to change the date/time Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
Barsnake Posted November 5, 2007 Posted November 5, 2007 User - M.Code And 6 - Then DD Tick MM Tick YY Tick HH Tick MM Tick Done Eng - If You Can Get In And Out OK Then 51 Tick DDMMYYHHMM Etc
suky321 Posted March 30, 2008 Author Posted March 30, 2008 User - M.Code And 6 - Then DD Tick MM Tick YY Tick HH Tick MM Tick DoneEng - If You Can Get In And Out OK Then 51 Tick DDMMYYHHMM Etc Thanks, worked a treat. Changed it back today as well when BST started.
