Optima Xl6 Internal Sounder
kevin291
hi
we've had an optimax L6 alarm system working fine since we moved in 5 years ago, but last night the internal sounder went off for no apparent reason, it then went off 3 hours later and then again at 4 & 6 this morning. the battery in the control box was changed last year so i dont think it's that. can anybody help?
thanks
kevin.
  antinode said:
What lights came up on the panel when it was doing this?
Hi
The only lights that came on were the power light and the green day light, there was no tamper light illuminated.
regards
kevin
No zone or Attack LEDs? I've never heard of an alarm going off without some indication on the control panel.
Trade Member
Hi antinode
I was thinking, could it possibly be the battery in the bell box running low?
regards
kevin
hi antinode
apologies, i have just checked the alarm memory recall and it says that it was a tamper fault (sorry), my problem now is finding out where it fault is.
regards
kevin
  kevin291 said:
hi antinode
regards
kevin
was the weather bad? how old is the bell?
Guest anguscanplay
my thought exactly
you not had anyone else working in the house?
  anguscanplay said:
my thought exactly you not had anyone else working in the house?
hithe weather was a bit cold last night but nothing too bad, and we havn't had any work done either, but thanks anyway for your help. i phoned up an engineer and he said that it could be the bell box and told me how to disable the tamper circuit, which i've done so hopefully i wont have anymore problems (or early mornings)thanks again for your help.regardskevin
Guest anguscanplay
banghead
one assumes he will be coming out to sort it ?
