Cable Tacker
morgan306
Like I said in my original post, there is a time when they are better than normal clips,like under carpets,I'm not looking to abuse them like the BT boys do. I had a Draper one many moons ago,but that was toilet.
if the cable was being fixed and not in trunk or on brick i would always use the gun, why not? as long as it isn't set to high causing resistance problems ect.
What does LBHA stand for? :banned:
local borough housing authority.[council scum contracts]
Guest anguscanplay
if the cable was being fixed and not in trunk or on brick i would always use the gun, why not? as long as it isn't set to high causing resistance problems ect.local borough housing authority.[council scumcontracts]
err but not plaster :no:
Oh I see!
I only use them where cable can't be conceiled, and clips would stand out too much.
There are Rapesco ones on ebay at the moment,the same ones that B&Q sell, are these the kiddies you are refering to as they seem a bit cheap?
when would that ever happen? all drops would be in trunk?
lol, before you answer that don't forget past PM's :D;)
Guest anguscanplay
nope - lost me, we use tube if its commercial anyway :)
Guest anguscanplay
by far the best, rapid brand.
i know adi gardiners and risco sell em. risco is the cheaper about
thats the one I got - twenty years and still going strong, new spring mind ( and guide bar,angled front edge,handle,cable holder and strength selector)
bit like triggers brush then
oops, i get one a yr or two if i'm lucky
nah it`s just like any tool, needs to be used right
rapisco
I have to agree with Angus,like all tools if used correctly and with care there should be no problem.
