Readings
Guest anguscanplay
Guest anguscanplay
BS7671 and BS7671 on site guide, happy reading! :P
thanks very muchly
is that a spur OFF a spur ? :fear:
it may come on its own circuit from the CU, in which case it would be a radial, which is fine.
but tbh, i never feed off boiler/heating supply, comes from doing council work when the just decide to rip them out and leave your panel dead. also alot of old tank spurs are fed from other switches ect. and you can end up with your supply being switched from other points.
also as you said angus as long as its fused down its fine. but that fails for us, ok if you are a spark feeding a radial of a socket for a conservatory ect as it can just be fused.
Guest anguscanplay
it`s like missing the old immersion heater switch in the kitchen - well it was live when i tested at the panel, thats cause they were wanting a bath you numpty.
lot to be said for coming off the loop in ceiling rose ?
nothing wrong with that i do it all the time, if they don't understand whats going on in one they shouldn't be messing with electrics.
only[sometimes] problem is bulbs going and tripping the mcb, but thats rare.
Just watch out for GU10's as these pull MCB's every time they fail.
My Amateur Radio Forum
Guest anguscanplay
good sparky wouldnt put the lights ( or the freezer GRR ) on the RCD side - well except they now stuffed that too with the 17th edtn
RCD? i said MCB.
Guest anguscanplay
RCD? i said MCB.
all a pain when the user blows the bathroom light but decided to " leave it off till the morning...." GRR
Not everytime, to my knowledge Osram are still the only lamp that have an internal fuse which wont take out the rest of the lamps and/or the main fuse/MCB
There are several now with internal fuse, I think they had to start installing fuses after so many problems from them, blown dimmers, tripped MCB's etc.
But most will still fit the el'cheapo ones! :rolleyes:
