Baterry Low Error Message On 9600 Control Panel
keatinmi
Hi,
My Scantrinic 9600 panel comes up with a "Battery Low" warning and the alarm keeps going off. Can someone please advise of the following;
1. Is this referring to the battery in the panel or one of the bells?
2. Is it a simple case of replacing this battery and what model battery is it for this panel.
4. Is it possible to turn off the alarm completely maybe through an engineer code or something.
I am a complete novice so please assume I know nothing about the panel except from a user point of view.
Any help with the above would be very much appreciated.
Guest anguscanplay
Hi,
1. Is this referring to the battery in the panel or one of the bells? PANEL
2. Is it a simple case of replacing this battery and what model battery is it for this panel. IT SHOULD BE A 7AMP
4. Is it possible to turn off the alarm completely maybe through an engineer code or something. YES
the system is ready for a service ( what happened to question 3? LOL)
Angus
angus you on 'speed' this morning............. :rolleyes:
