blakey Posted November 10, 2007 Posted November 10, 2007 Hi, I've recently moved house, and am trying to identify the Ademco system installed. There are no model numbers on the outside of the main box or the keypad, and I'm loath to open them up in case I set off the alarm ... So... a description: First, the keypad has no display. This threw me, since a search on google images for "ademco keypads" results in NONE without a display. Secondly: The keypad has a few LEDs running down the left side: Zones 1-8; "(9) Tamper", "(0) Day", and "Power". Below them are three LEDs running horizontally: a phone symbol, "Bat", "RF" Then the keypad is on the right, numbers 0-9, *, and #, with the following text above each key as follows: 1 - Full set 2 - Part set 3 - Night set 4 - (blank) 5 - Test 6 - Isolate 7 - (a phone symbol) 8 - Code 9 - Chime * - Escape 0 - Log # - Easy Set That's it for the keypad. The main box has nothing on it that stands out. Any ideas would be appreciated. The alarm went off tonight for some reason, and I'd had to disturb the neighbourhood again! Regards, Andy
mjw Posted November 10, 2007 Posted November 10, 2007 Hi,I've recently moved house, and am trying to identify the Ademco system installed. There are no model numbers on the outside of the main box or the keypad, and I'm loath to open them up in case I set off the alarm ... So... a description: First, the keypad has no display. This threw me, since a search on google images for "ademco keypads" results in NONE without a display. Secondly: The keypad has a few LEDs running down the left side: Zones 1-8; "(9) Tamper", "(0) Day", and "Power". Below them are three LEDs running horizontally: a phone symbol, "Bat", "RF" Then the keypad is on the right, numbers 0-9, *, and #, with the following text above each key as follows: 1 - Full set 2 - Part set 3 - Night set 4 - (blank) 5 - Test 6 - Isolate 7 - (a phone symbol) 8 - Code 9 - Chime * - Escape 0 - Log # - Easy Set That's it for the keypad. The main box has nothing on it that stands out. Any ideas would be appreciated. The alarm went off tonight for some reason, and I'd had to disturb the neighbourhood again! Regards, Andy could be a accord?? piccy would help
blakey Posted November 11, 2007 Author Posted November 11, 2007 AlterEgo, Thanks for responding. No, that's not it, unfortunately. I've been reading through some manuals, and I *think* it's an accord main unit. Still no idea what the keypad is. However, the accord user manual seems to offer instructions for both display and non-display keypads, and the notes tie up with my keypad. Only problem now is that the "(9) Tamper" light is permanently on, which I'm sure it wasn't before. I'll spend some time tonight finding out what that means, Thanks again for your help, Andy
camerabloke Posted November 11, 2007 Posted November 11, 2007 is it this one????? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
alterEGO Posted November 11, 2007 Posted November 11, 2007 is it this one????? think you missed the point mate
blakey Posted November 12, 2007 Author Posted November 12, 2007 is it this one????? No, as mentioned above, there's no display. But thanks anyway, Andy
nrao Posted June 23, 2008 Posted June 23, 2008 how about this? Hi, I have the same system just exactly in the same situation as you are dont know how to clear this and get it working, any help would be appreciated.
whistle Posted June 23, 2008 Posted June 23, 2008 Hi,I have the same system just exactly in the same situation as you are dont know how to clear this and get it working, any help would be appreciated. Short walk to the bin with it.
james.wilson Posted June 23, 2008 Posted June 23, 2008 It depends on your problem. Whats the actual issue? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
