Veritas R8 Plus
Chris170793
Hi All,
Is it possible to communicate to upload / download on a Texe Veritas R8 plus panel using PC Com? I have the Veritas software and the PC com. Normally I use PC com and Wintex when programming premier panels. Also I am been asked to replce the standard LED keypad with the LCD type - do the veritas LCD keypads support zone text e.t.c like the premier ones? and do they have mappable zones like the premier keypads ?.
Sorry for asking on here just wanted to check before I order any parts e.t.c
Thanks
Chris
Yes you can upload/download, its quite slow though.
The Excel LCD keypad can only be fitted to the R8+, no zone inputs on the keypad. Zone text can be programmed into the keypad (yes the text is stored in the keypad NOT the panel)
Thanks for that -breff, also intersting to know about the txt being stored on the keypad.
Out of interest does the excel keypad display status/faults/alarmed zones e.t.c like the premier.
The reason I ask is that this panel is fitted to my friends new house and he is used to the premier system I fitted to his previous house. I might just end up replacing the panel completely for a premier..... :rolleyes:
Fit a Premier.
