Accenta Alarm
Hi,
We had the main alarms box moved to an area in the WC where it was better located when we revamped. Since then when we are in the house and come in sight of any of the PIR Sensors, the alarm bleeps once. This happens each time any one of the family come in sight of the PIR sensors. Is there any way of stopping it? I believe we have a Accenta MINI.
Thanks
Tony
Hi,
Thanks very very much for that, will cheer my wife up. Also as I moved in the house about 5 years ago I inherited the alarm system so dont actually know which each zone is. Would it be possible for me to factory default and then set the zones my way?
Thanks in advance
Tony
  • 3 weeks later...
it is possible to do that, but an easier way would be to turn every zone on chime using the method uve discovered in the previous post, get a friend to enter each room one at a time and log which zone illuminates and chimes when that room is entered.
dan
dan
A better way is to use a Walk Test as described in the User Manual.
