Garry Posted November 13, 2007 Posted November 13, 2007 Hiya all. Triggers are not a problem but how do I doo my return do I have to put the resistors in the bell or at the RIO. Any help appreciated DUH!! Regards. Garry You can lead a horse to water but you carnt climb a ladder with a bell in both hands.
McP Posted November 13, 2007 Posted November 13, 2007 Hi The way my company does it is to fit a relay in the RIO usually a small AB relay. You put a permant 12v positve on to the relay and wire your negative return from the SAB into the negative terminal of relay. That way relay is always energized and if SAB is opened the relay will change state. Then wire resitors in to N/C connections with wires going to zone. Hope this helps. Scott
whistle Posted November 13, 2007 Posted November 13, 2007 McP said: Hi The way my company does it is to fit a relay in the RIO usually a small AB relay. You put a permant 12v positve on to the relay and wire your negative return from the SAB into the negative terminal of relay. That way relay is always energized and if SAB is opened the relay will change state. Then wire resitors in to N/C connections with wires going to zone. Hope this helps. Scott Thats the way i would do it. BUT. If its not a smart rio you will find the output wont give enough current to trigger a bell. If its a normal RIO set the bell in SCB mode and it will work fine.
daveboy Posted November 14, 2007 Posted November 14, 2007 Garry said: Hiya all.Triggers are not a problem but how do I doo my return do I have to put the resistors in the bell or at the RIO. Any help appreciated DUH!! Regards. Garry Don't fire the strobe directly off an output use a relay.
Garry Posted November 16, 2007 Author Posted November 16, 2007 Thank you guys for your helpfull replys. Have a great weekend. Garry. You can lead a horse to water but you carnt climb a ladder with a bell in both hands.
