Average Domestic Price
What do you Charge
31 members have voted
  1. 1. What do you Charge
    • £900+
      1
    • £800+
      2
    • £700+
      2
    • £600+
      5
    • £500+
      3
    • £400+
      5
What would you lot charge for the System Below..? or Simillar..?
Gardtec 816 Metal
Contour Rkp (3 Keythobs)
Bellbox (nova2)
Dummy
2 X Mrs`s
4 X Pir`s
All assuming a 12 HOUR (1 1/2 day) installation, for 1 Engineer. He fits everything himself, from the fused spur to the bellbox..and all wiring where possible is under the floorboards....
This is a DD243 compliant install, as the customer may want monitoring at a later date.
Mrs = Magnetic Reed Switch
or a
Door Contact to most people..:)
Initial would probably charge around £800 + VAT for a system of that size but that would include using top of the range equipment ie Aritech. Also, the fused spur would have to be fitted by others as Alarm Engineers are not qualified sparks.
By the way, what's a keythob?!
UTC - The dawn of a new era !
Keyfobs are used for remote setting (ACE Technology)
I bet you knew that though :) your just taking the "P" cus I spelt FOB wrongly :)
Guest Peter James
Dave I voted wrong I didnt read your post only the heading and assumed audible only.
So I voted £400+ but 12 hrs and the kit install only would be £600+ not inclusive of the first years monitoring.
Please could you change my vote accordingly.
Pete
