Premier 48 And Shunt Codes
whibbs
can i use shunt code on a prem 48 it not how can i set up the zone listed below
i have set one zone to a door contact on a store shed thats set as a 24 hour zone can i set a specil use code just for that zone only.
Wayne Hibbs
Put it in its own area, program as guard, assign another code just for that area, set the area to time arm or instant arm, assign both areas to your keypad.
ok thanks will give a go
Wayne Hibbs
