whibbs Posted November 17, 2007 Posted November 17, 2007 have set up a premier 48 with a gsm module unit i have set up wintex comms details ARC1 as sms messaging all works ok but have tried to set up ARC2 as sms messaging as well but can not get to send details to both ARC1 / ARC2 i am not sure that i can use both at the same time . as the company i have fitted for need to send details to both the branch manger /security officer plus there head office has any one tried to do this before if so what do i need to do to make it work? Wayne Hibbs
breff Posted November 17, 2007 Posted November 17, 2007 You have to select the option to dial all numbers. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted November 18, 2007 Author Posted November 18, 2007 you trade Wayne (size7) ? yes but alrms not my main job am a sparky Wayne Hibbs
Guest anguscanplay Posted November 18, 2007 Posted November 18, 2007 yes but alrms not my main job am a sparky then go get some manf. training if your going to be using this panel regularly, (and brush up on your regs too, same as you`d no doubt advise someone starting as a sparks) it`ll pay for itself in the longrun.
