nitro Posted November 18, 2007 Posted November 18, 2007 hello there, i have a rs232 module online with the galaxy 60 ok but i just cannot get the galaxy gold to connect to the module via d9 com port (rear of laptop)to the d25 port (rs232 mod) using a rs232 cable purchase from well know electronic shop. i have set the baud rate to 1200,stop bits=1,data bits=8,parity=even,transmission=rs232 on the module and the laptop com port 1 set at same setting as above. i have been tweaking various connection/setting to no joy,have i miss any others option??? the galaxy gold keep coming up 'cannot communicate with remote module' can anyone shed a light in this matter??
barooga Posted November 18, 2007 Posted November 18, 2007 hello there,i have a rs232 module online with the galaxy 60 ok but i just cannot get the galaxy gold to connect to the module via d9 com port (rear of laptop)to the d25 port (rs232 mod) using a rs232 cable purchase from well know electronic shop. i have set the baud rate to 1200,stop bits=1,data bits=8,parity=even,transmission=rs232 on the module and the laptop com port 1 set at same setting as above. i have been tweaking various connection/setting to no joy,have i miss any others option??? the galaxy gold keep coming up 'cannot communicate with remote module' can anyone shed a light in this matter?? You sure you got the right cable?? Check continuity between the the relevant pins between both D types Can't comment specifically for the above but it is usually: 9W - 25W P2 (Tx) - P2 P3 (Rx) - P3 P5 (0v) - P7 Growing old is mandatory, growing up is optional
nitro Posted November 18, 2007 Author Posted November 18, 2007 You sure you got the right cable??Check continuity between the the relevant pins between both D types Can't comment specifically for the above but it is usually: 9W - 25W P2 (Tx) - P2 P3 (Rx) - P3 P5 (0v) - P7 ok i willl check tomorrow and let you know,thank .
arfur mo Posted November 19, 2007 Posted November 19, 2007 You sure you got the right cable??Check continuity between the the relevant pins between both D types Can't comment specifically for the above but it is usually: 9W - 25W P2 (Tx) - P2 P3 (Rx) - P3 P5 (0v) - P7 i would add there are 2 types of lead 1) serial (direct pin to pin like an extension lead) 2) null modem (reverses ie P2 - P3 and P3 - P2) as used with er! modems you will need the right one for it to work regs alan If you think education is difficult, try being stupid!!!!
