Perimeter Protection
aleksandras1234
Hello, I've question about perimeter protection system.
What kind of perimeter protection system could you
suggest me to design in the place where is quite
intensive vibration - powerful compressors working
(the distance from fence of perimeter is about 50 meters).
Sure, the vibration would be just near those compressors -
so could I to protect with wire system - such as "defensor" ?
What kind of other systems? wires, microwave, IR?
There area of domain is about 300x350 meters.
Thank you
Only used it once but was a good job "Guardwire" you can set it up to ignore background noise such as the compressors from what I remember BUT it was 5 years ago.
Thank you
If the ground is quite flat and the fence line staight use microwave backed up by radar guided CCTV
Ilkie
  • 2 months later...
Guardwire is the way forward. Made by a company called Geoquip I believe.
don't know if this helps,
gardtec make the 'watch out' external pir in a radio version, comes with long range lens can be pole mounted, if suitable would be easy to install and a relatively cheaper option.
take a look on gardtecs site for demo video's
regs
alan
