Citadel Xr1
GARYF
Hi everybody, i hope somebody can advise on the following:
I am working on a Citadel XR1 panel with a matching RKP. The property is a bungalow so the exit/entry (final door) is the front door - zone 1. The pir's are as follows:
Kitchen, living room, dining room, downstairs bedroom and vibration detector on window - all zone 2 - is this ok?
Back door - zone 5!
When the owner sets alarm to go to bed, she has to walk back into room to get upstairs. this zone(2) is time inhibited. This is fine until she re-enters to unset alarm and it then goes into immediate alarm!
When leaving the house, she now wants to use the back door but the nearest RKP is near the bedroom so again she has to pass through zone 2. Again, fine until she re-enters then activates immediate alarm again!
The bungalow now has an upstairs. What i plan to do is:
Move existing RKP to side of back door.
Add another RKP to upstairs.
Reset alarm to factory settings.
Reprogramme.
Can anyone tell me if i should connect the back door to zone 1 (along with front door) or allocate zone 3 to this? If needs to be separate (z3), how do i programme to make z3 to be entry/exit route as well as z1?
Many thanks in advance,
Gary.
Back door - zone 5!
Reprogramme.
Gary.
if you can crash it, you can re-prog it. its all in the manual.
if you can't find a manual it is known better as a 'optima G3' with 'accenta' RKP rather then a Citadel XR1, the manual won't be hard to find.
Good Luck
