Newlec Nl5702n
beeco
I live in a student house which is fitted with a newlec nl5702n fire system. Last night all the downstairs lights went out which for some reason made the alarm go off. We entered the code but the box keeps on beeping and the power fault and general fault lights are on. This has kept me up all night so any help would be great.
cheers
cheers
This post might help, found using search.
Manual
cheers
The Newlec panel will not self reset when the power comes back on (faults are latching), you need to enter code plus press reset.
Sounds like you have already done this?
Possibly the power outage has allowed the internal back up battery to discharge to a point where it cannot recover and must be replaced.
You will also be unable to totally shut off the fault buzzer, if you mute the buzzer it will still sound every 20 secs or so.
You need to get your landlord to call out the service company ASAP.
Fire Member
Guest Cerberus NI
cheers
Also sounds like they have derived the mains supply from the lighting circuit.
Thanks for the replies, we've managed to get someone to come out and have a look at it. Probably not gunna help that one of the lads in the house attacked the sounder fuse with a screwdriver to try shut it up. It's off to maplins i go for new ones.
Guest Cerberus NI
Oh dear!! :rolleyes:
only gives more reason to have it installed right in the first place.
usual result=**** install powered from lighting circuit. Bulb blows,fault tone goes, tennant takes matter into own hands and butchers the system.
putting everyone at risk.
probably never been serviced either.
pity your mate did not blow himself up instead of not calling out your landlord to deal with it...
