whibbs Posted November 25, 2007 Posted November 25, 2007 hi i have a problem with a gsm module i have istalled to premier 48 control panel when i try to call the gsm unit with my nokia N70 mobile using wintex, and the phone set up as a modem with me laptop get a error (he the panel does not answer)! if try to connect using a morotola phone it works ok can any one help Wayne Hibbs
barooga Posted November 25, 2007 Posted November 25, 2007 hi i have a problem with a gsm module i have istalled to premier 48 control panel when i try to call the gsm unit with my nokia N70 mobile using wintex, and the phone set up as a modem with me laptop get a error (he the panel does not answer)! if try to connect using a morotola phone it works ok can any one help 1st thing to check would be the settings on the phone. Are they the same as the motorola? Growing old is mandatory, growing up is optional
whibbs Posted November 25, 2007 Author Posted November 25, 2007 1st thing to check would be the settings on the phone. Are they the same as the motorola? not sure what to check for ? any ideas ? wayne Wayne Hibbs
whibbs Posted November 29, 2007 Author Posted November 29, 2007 not sure what to check for ?any ideas ? wayne can any one till me the best modem setting to use for the nokia N70 Mobile phone i am trying to connect using he phone and wintex to the gsm module any help please Wayne Hibbs
