Fitting Mains Suppressor To Securit 800l
jonajona
This post is //.B.W.F.// eyed.
One minute on about mains suppresion then 12v spikes.
The above image of the 12v spike filter is the wrong one to fit and will diddly squat.
Fit a mains spike filter to the 230v connections in the panel, job done.
agreed imo,
but it is as designed to go into the 12 volts not mains so might get a nice pop if you try it.
far cheaper to fit 2 x 100 pf caps center tapped to earth, and making inductors by wrapping the leads around a small screwdriver 5 turns to make a coil, but i'm just old school so please ignore me everyone :)
regs
alan
Guest anguscanplay
far cheaper to replace the battery and safer too (and the tamper terminals)
RFI ? it`s a myth
Explain the myth theory please.
how do you replace tamper terminals?
And i'd fit a suppressor to the Central heating - It appears to be the cause.
Or sort out why it is kicking out spikes.
Growing old is mandatory, growing up is optional
Guest anguscanplay
"myth" - look here
you dont, you read the O/P`s previous posts and relate the comments to the advice he recieved then
Guest anguscanplay
only time I`v seen something comparible was when Dyson vacuums first came out, customer said alarm went off when she switched it on to hoover the stairs - turned out it was one step and a nail through the cable - still not seen mains induced tampers
he, he,
went to help out on a troublesome job for another installer last year, he was totally lost, every so often client using their gas fueled ascot water heater set off this alarm system, they had fitted extra spike suppression in a vain hope as - it's gas - old type with a pilot light - i.e. no electricity used. :rolleyes: .
turns out his engineer had used an existing cable which was buried in the plaster and a heater fixing bracket had squashed it, vibration when used then caused on a short and so a tamper, but only every so often.
now thinks i'm a genius (but you lot know i am :whistle: )
regs
alan
Guest anguscanplay
just remembered another one - tumble dryer triggering keypad tamper everytime it was used (always,always 20 mins into cycle) hmm - loose fuse on PCB
I know what myth means Angus ,but what do you mean by rfi being a myth?
