dgm Posted November 27, 2007 Posted November 27, 2007 Hi Guys, Can this panel do the following. a) Be set with fobs for both full set and night set? B) Be programmed to only be set with fobs and not accept codes to set the system ( at present it does both ). c) Programmed to send an abort signal? Thanks
The Arab Posted November 27, 2007 Posted November 27, 2007 Have only ever programmed fobs as option 12 timed set in max options of code so think you can only programme a fob/max to do one option and yes you can programme system to send abort Trade Member
barooga Posted November 27, 2007 Posted November 27, 2007 Have you spoken to the guys at AT? Having just installed it i'm sure they'd be willing to advise. Growing old is mandatory, growing up is optional
Guest anguscanplay Posted November 27, 2007 Posted November 27, 2007 A - should be B - not recommended (keep one code incase the reader fails) C - should be
dgm Posted November 28, 2007 Author Posted November 28, 2007 As it's a new panel AT were not fully aware of what it can or cannot do, they are coming back to finish programming it and if no good they will swap it out for a Scantronic for me. Wanted to clarify that the panel can do what I want it to do as I am otherwise happy with it and all aspects of the install!
whistle Posted November 28, 2007 Posted November 28, 2007 Hi Guys,Can this panel do the following. a) Be set with fobs for both full set and night set? B) Be programmed to only be set with fobs and not accept codes to set the system ( at present it does both ). c) Programmed to send an abort signal? Thanks Yes to all
dgm Posted November 29, 2007 Author Posted November 29, 2007 To comply with DD243 En50131 and the new PD6662 do you have to set and unset with a prox or can you set with a code and then unset with a prox so it complies? Trying to get a handle on this...
Guest anguscanplay Posted November 29, 2007 Posted November 29, 2007 To comply with DD243 En50131 and the new PD6662 do you have to set and unset with a prox or can you set with a code and then unset with a prox so it complies?Trying to get a handle on this... in theory yes, but in practise no ( I certainly don`t encourage or even suggest it to my customers) too easy to //.B.W.F.// things up Edit - I didnt type a //.B.W.F.// type word i typed //.B.W.F.//
