Power Cut
horspool
after a long power cut, when the power came back on the green power light is on but none of the control panel buttons work so hence cannot set the alarm
many thanks martin
many thanks martin
post make and model of control panel would help no prizes for guessing guys). most likely the system needs down powering and then restarting with a decent battery installed, but that is really is a job for a competent engineer for your own safety
regs
alan
Guest Cerberus NI
What your question though Martin??????
I would reckon Martin is referring to the fact that the buttons are not operating after the power failure,non??
regs
alan
thanks alan for your reply, i have some instructions of how to clear nvm is that the powering down you mean? if so is says to conect terminals xx and xx and the little piece of wire is inside the control box to conect them together. but which are terminals xx and xx.
many thanks martin
hello, the green light is on for power but none of the control panel buttons work so cannot set alarm
the control panel is optima xm6 which is based on the optima xm
many thanks martin
many thanks martin
NO!, clearing the VM will also clear al the programming back to factory default, so if the installer has changed things then those settings will be lost along with all the codes.
the keypad and main control unit are both microcomputers in their own right, but need to be in sync to be able to communicate, thats why powering down and again then powering up in the proper sequence is very important, the manual you have should relate to it and what the manufacturer suggests is the correct method.
as an example, if the battery is fully discharged actually duff, it might apply say 10 not 12 volts when reconnected, the keypad may respond but the main cpu might suffer or vise versa, so starting up on the battery can cause problems you might not expect.
some panels do clear their memmory which they should not on power failure, that why i asked the make and model.
regs
alan
many thanks martin
the sequence for power up is mains first then battery on that panel,
rather daft as the problem you had of a power down is fairly common :rolleyes: (so a very 'p' poor poor design imo)
Regs
Alan
