Accenta 8 Program Not Working
Duffbeer
Hi all
just found this forum and wondered if anyone can help!
I have just installed a new Accenta 8 version 4 panel (LCD RKP) and cant seem to program the part set options, I keep reading the manuel for any thing I've missed but I'm at a loss, begining to think panels not working properly.
problem, in engineering mode go to program set up, which it asks you which one you want to alter (1 2 or 3) I press 2 because I want to configure 2 for my part set options, I then go through each zone toggleing them to be used or unused,I have tried pressing set after each zone is done and tried it without but when you try to set the system in program mode it will only allow full set ie program 1?!?
Does the program mode need to be turned on? can't find anything in manuel, incidently when you enter the user code for set and then press program the system does not stop counting down to set like it should do.
Everything else works perfectly.
PS
have not tried reseting panel to default yet, trying not to loose rest of programing.
any suggestions would be much appreciated :unsure: banghead
Nik
You need to asign an exit mode to program 2 or the panel will always revert to program 1 on arming.
hope this helps
Many thanks I will give this a try
