Alarm System With Door Contacts Fitted To And A Sliding Door
hi can any one help with the problem below
i need to connect a set of door contacts
the problem is that door i am fitting the contacts to is fitted inside a sliding door
the sliding door 10' wide x 15' high and needs to open to allow access to the showroom so stock can brought in by fork lift trucks.
fitted inside that door is a smaller door that is 3' wide x 7' high and is hinged open out to customer access in and out.s
how can i wire up to the door contacts i need some can of plugs that disconnects when the door slides open and reconnects when the door slide shut
one part fitted to the wall side and the other part fitted to the door face
does any one have any ideas
Wayne
Wayne Hibbs
what about a wireless contact and receiver mounted above the door casing witihin say 10 ft of sensor when closed
07475071344
Wayne
ho whibbs
seems to me any arrangement would not be compliant to the latest design Eu stature's.
is your system under contracts? and what is the risk involved i.e. what is in the showroom carpet tile adhesives or expensive jewels?
not all is lost, but we need more info to be able to offer any serious help
regs
alan
that may work ?
Wayne Hibbs
ho whibbs
regs
alan
a very large showroom in a timber yard
i throught of some kind of a plug system that is wired so that if the hinged door is open the alarm will go off
or if the sliding door is open it also set off the alarm
i was thanking if wired correctly if any one trys to disconnect the plug it will also break the zone setting of alarm
the sliding door slides for left to right and is on the out side of the wall so i a can not hard wire it up
regs wayne
Wayne Hibbs
regs wayne
id still sugest a wireless contact tbh
it will be quite difficult reading the ops original post to hard wire the sensor.
07475071344
ok thanks
Wayne Hibbs
regs wayne
the sliding door section should be easily protected by heavy duty wired contacts (assuming they are in good condition). if the door is the type where the frame is removed then an expanding lead is often used to allow removal and connecting the contacts.
this really is getting into the more specialised area so you really would be wise to invite some local companies to quote for the work as they can better asses your needs and the situation in hand.
recommending 'blind' is not really a good idea, there are many options but picking the best is not easy and our efforts based on assumptions may mislead rather than help you.
regs
alan
How about this type of arrangement , used on sliding doors on vans to pass feeds to cdl motors etc.
thanks for for the idea i thank give it a trywill go and get a set in the morning thanks wayne
the sliding door section should be easily protected by heavy duty wired contacts (assuming they are in good condition). if the door is the type where the frame is removed then an expanding lead is often used to allow removal and connecting the contacts.this really is getting into the more specialised area so you really would be wise to invite some local companies to quote for the work as they can better asses your needs and the situation in hand. recommending 'blind' is not really a good idea, there are many options but picking the best is not easy and our efforts based on assumptions may mislead rather than help you.regsalan
ok thanks
Wayne Hibbs
