Guest anguscanplay Posted December 4, 2007 Posted December 4, 2007 you just need a long coily door loop - did one myself recently
arfur mo Posted December 5, 2007 Posted December 5, 2007 How about this type of arrangement , used on sliding doors on vans to pass feeds to cdl motors etc. tamper might be a slight issue? regs alan If you think education is difficult, try being stupid!!!!
whibbs Posted December 5, 2007 Author Posted December 5, 2007 tamper might be a slight issue? regs alan i as thinking of that i will find a way wayne Wayne Hibbs
arfur mo Posted December 5, 2007 Posted December 5, 2007 i as thinking of that i will find a way wayne this is not something to do if compliance was an issue, going back in time (mine ), if you do use some form of plug and socket to connect the wicket gate, you could fit a key-switch to allow you bypass the tamper before disconnecting, obviously when locking up refit the plug and return the key-switch to the armed position. just to be safe, make sure you have decent dual-tec protecting the loading bay as backup just in case it develops a fault or you forget to reconnect it, but got to say as others have radio contacts offer the simplest and most effective solution imo. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted December 5, 2007 Posted December 5, 2007 i as thinking of that i will find a way wayne LONG COIL`Y DOOR LOOP
breff Posted December 5, 2007 Posted December 5, 2007 Active beams on the inside instead. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
whibbs Posted December 5, 2007 Author Posted December 5, 2007 Active beams on the inside instead. never throght of them wayne Wayne Hibbs
whibbs Posted December 6, 2007 Author Posted December 6, 2007 Whibbs - you got me on ignore? just had a few bad days Wayne Hibbs
