Guest Davidwil Posted April 30, 2004 Posted April 30, 2004 Hi, I have got two CD3008's connected to a CD95. I set the switches in the control pad correctly so they both have a different adress on the data bus. But i can only use one of controllers. The second one only displays the software version. Both of the controllers work without a problem when i connect them seperatly. Does anyone know if i als have to change a setting in the CD95? About then years ago i anstalled loads of these things, bu now i don't excaclt know what to do to get the second keypad working...... Does anyone have the answer for me?, i also havn't got the installers manual, so this makes it even harder to find out. Can anyone help me? Greetings, David
j.paul Posted April 30, 2004 Posted April 30, 2004 Hi David I think you need to go into eng programming section "outputs/remotes" and "install remote" which will install the keypads. Hope this helps jpaul There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest lieven Posted May 10, 2005 Posted May 10, 2005 Hi DavidI think you need to go into eng programming section "outputs/remotes" and "install remote" which will install the keypads. Hope this helps jpaul 12143[/snapback] If the keypad is giving the message NO PANEL DATA, what's wrong ?
C.S TEK. Posted May 11, 2005 Posted May 11, 2005 It could be one of two faults. There is a chance you've addressed it the same as an Expander or you've addressed it on a higher remote than 8. Keypads on the CD95 can only be addressed 1 to 8 ,address 9 and above are for Rle's only Hope you sort it Chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
Guest jabaroon Posted May 1, 2006 Posted May 1, 2006 Ive just had something similar with a CD34 on a property that I rent out. Got a call from the tennants to say that the alarm wasn't working. When I got there the keypad was telling me "rd-no panel data". I have checked all of the usual bits such as ensuring that the jumpers on the CD3008 are set to keypad one. Have also done a full reset on the panel but no matter what, I cant get the panel to recognise the keypad. There is no other expanders or keypads on the system so Im pretty confused! Any ideas?
