Eneo Mini Trax Dome
satsuma01
has anyone come across an eneo mini trax speed dome before it seems quite a new camera on market.
wondered if anyone had used them?
:rolleyes:
07475071344
Used 1 about a year ago, from memory not day/night and limited to 359 deg pan.
It worked well as internal dome with some other externals and the usual Eneo keyboard, usual Eneo speed dome pic quality.
would you recommend it for outdoor use with good lighting?
07475071344
I can't remember the spec now - obviously suitable for outside by its construction but dont think its day/night so you would need to check what it needs for lighting.
