C&k Securitech...
pigsinspace
After 14 months of living in my new house without touching the alarm system or the mysterious metal box in the airing cupboard, earlier today the missus said, "What's in that box?". Throwing caution to the wind we opened it up and saw the word "security". By the time the penny had dropped the tamper alarm was going off in the keypad downstairs.
I don't know the code number, the previous owner didn't know the code number and as far as I can tell the alarm hasn't been set in 5 or 6 years at least.
What happens if i rip out the little buzzer in the keypad? Does the alarm go off? Or do I just deserve the nagging little drone for being such a bleedin' numpty???
Link to comment
https://www.thesecurityinstaller.co.uk/community/topic/21600-ck-securitech/
Share on other sites
the siren outside may sound and any buzzer or sounder in the main box may also sound, if you want it disabling completly best advice is to get a engineer in to carry out this work. for security reasons this sort of info cannot and will not be given out here as we dont know you personally and therefore cannot say what you level of electronic security equipment and electrical works understanding is. for your own safety youd be best advised to get a qualified engineer out to your alarm as soon possible..
hope this helps.
07475071344
You need to call an engineer, there are ways round it, but then, you could be a burglar, or a burglar could read this.
An engineer should be able to default this panel back to factory (though they sometimes die in the process) and give you a new code
- have you tried a few generic codes in it to make it stop - in case the previous owner left you with an easy code?
Pulling wires out without knowing what you are doing can be dangerous to you and your property.
hope this helps.
OK understand your position. I can't afford a security engineer though, so I'm now left wondering wtf to do!!!
without being rude or unfair to o/p maybe opening that 'box' up was not such a good idea. how do we know you are not burglar bill??
07475071344
Turn off your mains with the main breaker and buy some candle's, you may live in the dark but at least you sorted your alarm out on the cheap.
what about the batteries/battery backup :hmm:
07475071344
